Re: What did you do to your boat today? Vol 2.0
89 Camaro: rewired the cruise control harness, but when I go to activate or turn on cruise control my gauges fuse blows. I'm trying to get cruise control to work so I can diagnose why my speedometer doesn't work, and I'm hoping it's not a capacitor and/or resistor that loves to blow on these. Still have to change sensors until I fix my engine light as well, so that means I have to correct my vacuum lines, but at the same time I want to delete a/c and smog because they're taking up way too much room in my engine bay. I still have to change the driven gear in the trans and fix the kick down tv cable connector so it stops popping off. I like the whole downshifting thing that comes with WOT.
To-buy list:
Adjustable fuel pressure regulator, headers, egr valve, egr solenoid, shorter serpentine belt for a/c and smog delete, another pcv valve for extra ventilation, gray 44 tooth driven gear to match the speedo to the new 3.73 rear end, new tires for when they finally stop burning every time I tap the gas, fuel injectors (2), ignition coil, lots of electrical tape. MAT sensor, TPS sensor, and quite a few more.
And at some point I am literally going to have to rewire a large amount of what the previous owner did under the dash. Electrical gremlins are a-plenty, and I have a random stalling issue right now as well.
-Apex Aaron
