Hey Everyone,
How much of a PITA is it to replace the AC condenser on a 2001 GTP? What all is involved?
Mine has severe leak. Leaks out an AC charge in about 48hrs. Dye confirms it.
Thanks for input...this forum is the best![]()
Is that on the drive side of the condenser? Upper or lower part of it?are you sure it is the ac condenser? I had an ac leak, and it was just the nipple near the condenser that needed replacement.
Dammit, he did say condenser, I read compressor.
Remove the fans, remove the rad hoses and transmission cooler lines, raditor then can come out and you have full access to the condenser.
its possible to pull the condenser without pulling the radiator. it's a tight squeeze but it can be done especially if you can't get the trans lines off the radiator.
also replace the accumulator / dryer when you replace the condenser. and don't forget to lube O rings with some PAG oil and keep it all clean.
