Vac line routing
hensleya1
Paging Scotty or anyone else who knows what to do here.
Top swapping an 04 LeSabre. Can't figure out what to do with this vac line. The standard L67 diagrma says this line goes "to accessories" but I don't have this line (or I can't find it).
So, questions: if I'm not seeing it, where is it?
If I don't need it, can I cap it?
Thanks.
from another thread "Middle one goes to the AC ducting control (the vac line that original connected dead center on the back of the L36 intake manifold)"
http://www.grandprixforums.net/threads/10045-Vacuum-diagrams-from-top-swapped-car
not sure if you have that line in a lasabra or not. if you dont see one off the fire wall. cap off that port so its no a leak.
it would be the one that was next to the na brake booster hose in the na upper intake.
i looked at the N/A intake and it was capped there. I assume the HVAC controls are electric rather than vacuum powered. I assume I'm good to cap it on the supercharger then?
