    TIPS:
FS: DHP Tuning Setup (Laptop, DHP, PLX WB O2)
TommyGloves
I'm selling one of my tuning setups. Selling as a package. Invest in yourself...become a 3800 tuning god!
You just need a good OBDII port, install the WB in your DP and 12v power and ground for the PLX wideband!
This is all setup and ready to go!
Dell Inspiron 700m Laptop
* Replaced LCD last year with a Dell replacement
* Newer, genuine Dell 8-cell battery (Battery is still healthy...see pic)
* Genuine Dell AC Adapter
* Fresh Windows 7 Pro - Minimal software installed on top.
* 2GB RAM, 2.0ghz M CPU, Wifi, DVD Burner
* I've pre-installed all the DHP, UVScan 2 and 3, Tiny Tuner Suite, etc.
* All drivers installed and tuning software setup out of the box
* Everything works and it's in great shape
DHP PowrTuner AVT-841
* Keyspan adapter included
* Pre-wired A/D Inputs (1: PLX WB O2, 2: PLX NB O2, 3: Open pigtail for a 3rd sensor or signal wire. I ran an Autometer fuel pressure sender.)
PLX SM-AFR (Gen II)
* Like New Bosch Wideband O2 sensor (has ~1,000 miles on it)
* Just need to connect 12v power and ground
* Modified to allow a direct, digital serial communication (works with a special version of UVScan II installed on the laptop. It's the serial cable coming out of the PLX. Connects to a USB port on the laptop . https://forum.efilive.com/showthrea...Serial-upgrade&p=129268&viewfull=1#post129268)
* Includes the blue USB to Serial adapter pictured as well
I'll include a Windows 7 Pro Recovery CD and backup CD of the tuner software.
Package Price: $500 picked up in Palatine, IL. UPS/FedEx Shipping, Insurance and 3% Paypal are extra.
Shipping from Palatine, IL
PM or post with questions. Not looking to part this out at this time. Thanks for looking!
Noob question, I assume you have to add another O2 bung for the wideband? Or can you remove pre-cat O2 and insert wideband just for tuning?
Rick
GTPMayhem
you can add a bung or delete the rear o2 and put the wb there. you need the other o2 all the time.
and do you have a gauge for the wb or is it for direct hook up to the laptop? curious about the cable off the plx box there. how does that work? im still trying to get mine to read right on a scan.
if it is like my wideband, on my wideband there is a serial output/input cable so if plx has software, you can see what the gauge is reading on your computer. on mine, you can also program the gauge itself, like speed up or slow down the data rate, or change the colors that the gauge shows. the serial output is really only useful for programming because you can't incorporate any other data to display with it.
I do not have a the gauge, I just had the serial cable connected to the laptop via usb. Steven Chesser had made a version that allowed the direct serial connection with UVScanII back in the day. It worked much like the direct connection he did with the Innovate WBs. That's what's installed on the laptop.
I believe the guage you are talking about hooks into the headphone-style port on the PLX box. This is also a serial style communications. It just sends the AFR data bits to the guage for display.
is there a schematic to make that cable? looks simple enough, just need to know what wires to tie together from the plug there to the serial cable.
Its in this thread somewhere...lol..start on Page 9: https://forum.efilive.com/showthread.php?7726-PLX-SM-AFR-Serial-upgrade
You're just tapping power, ground and signal. I can open the box and take a pic on where I hooked it up.
This looks like it might work (its a later post in that thread): http://www.ebay.com/itm/200983912175?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Here's pics of the modification. Feel free to move all of this to a new thread.
The zip tie is for strain relief on the cable inside the enclosure.
So the community DB is full. I shared a folder/file with the Community DB from my DB. You can find the PLX version (UVSCAN2.0-61209A-DirectPLXSMAFR.zip) under the Share section. (https://www.dropbox.com/share)
You'll need to go to the Setup menu tab in UV to tell it what com port the PLX is hooked up too. The PLX Direct PID is under the Fake PID -> PLX AFR WIDEBAND DIRECT. It's hard-coded to 14.7 AFR scale.
