Lotsa Questions - MODs Mostly
71GP2000GTP
Hello.
Going from a 2000 GTP to a 2004 GT...I know, I know...it is newer not necessarily better. I'm not a body guy and couldn't keep up with the rust on the 2000.
I have been searching the forums and I found some items and wanted more info and I question I couldn't find an answer to:
  1. 180* Thermostat - Why? Cooler? Any other bits of wisdom are appreciated.
  2. K&N Cone Filter - Is this just a matter of removing stock air box and slapping the cone filter in place?
  3. This GT seems sluggish after the GTP...no mystery there...feels like the tranny needs to shift later, like the 'Performance Shift' in the GTP. Is there a mod that a weekend mechanic can do to squeeze a little more out of the tranny?
This is my daily driver so I need mods to be tried and proven.
I still have the GTP, so if there is anything she can give up for the GT, please suggest. Other than the obvious, like drivetrain swap, remember weekend mechanic.
Thanks! in advance.
First off, congrats on the 04+, welcome to the 7th gen club. Lol
180 tstat is only good if the engine is heavily modified and needs to stay cooler to prevent detonation.
K&N filter can be slapped on, but the best choice is a intake that can keep the filter from bouncing around. I made mine out of 3 inch PVC. Seems to work fine.
There's very little the GTP has to give up, the entire drivetrain as a whole won't work without a large amount of modification.
http://www.grandprixforums.net/threads/17482-Safely-Modding-Your-3800-Powered-Car!!
That's 90% of the information you are looking for. You can keep some of the engine parts for a top swap, but you would need a Gen 5 supercharger. The Gen 3 supercharger on the GTP now would need modification of the PCV system in order to work.
The heads, valve covers, harmonic balancer, ignition coil bracket and tensioner with all of the bolts, studs and nuts, idler pulley and bracket, and possibly the injectors, can all be used for a top swap.
If you keep the 04 N/A for now, ZZP has a Front and rear PLOG if you want to spend the money, but headers will be needed, albeit more expensive, if you decide to add boost later.
For the trans, a TransGo shift kit will tighten up the shifts and make them feel more solid and snappy, but if you want the trans to hold up to more power, you will need hard parts and a good amount of money for those stronger parts.
A good tune will be what wakes up the car the most, ordering one from a company doesn't really give you what you want. There's a number of people on here with tuners, find somebody nearby and convince them to tune your car. That's the quickest way to get the most out of the car.
Suspension upgrades are also something you will want, cornering and braking sucks on stock GPs. Here's another link to read and learn yourself: http://getoverkilled.ca/wbodytech.html
Good luck with the GT.
the theory behind a colder thermostat is that when your engine reaches the temperature specified, then the thermostat opens and keeps the engine running at a colder temperature. one problem is that if you put a colder thermostat in, the check engine light will come on for a P0128 code. another problem is that if you live in a colder climate, like me, is that your engine won't reach it's optimal operating temperature and you will suffer from reduced fuel economy. However, I will say that the P0128 code can be disabled and the reduced fuel economy does not happen all the time. one last thing is that if the P0128 does trip and it is cold outside, your heater may not work.
you could just take the airbox off and put an open cone filter on the end of the throttle body. my car is a 2001, so it doesn't look the same as yours, but the idea is the same.
as far as the sluggish and dull performance, you should get a tune. you can get a shift improvement kit as well, but a tune will do more for the car. I wouldn't bother with mods on a N/A car because the returns don't make much more power. a top swap or a turbo kit will help a great deal, but they are a substantial amount of work to install.
Not quite, 04+ has the MAF in the middle of the intake, not inside the throttle body like yours.
Our MAF sensor is inside that black tube with the connector on the side. It needs to be part of the intake, either with couplers or a intake tube designed to hold it in the center of the airflow so it measures correctly.
you can still leave the maf sensor on the throttle body and put a open cone filter on the end of the maf sensor
I tried that myself, it flopped around and kept hitting the connectors for the PCM. After one of the clips cracked, I decided that was a bad thing.
That one is a good example. LQ4 MAF is substantially shorter than the stock 04+, but that 45° aluminum elbow is what I was trying to get the point of, if it's not a rigid intake or braced somewhere, it's going to cause problems.
Not really.
My stock MAF on my truck is built into the air box neck coming off it, it's as far away from the throttle body as it can be and it makes no difference. I'd say it's over 20+ inches away at least. As long as there are no leaks between that and the intake manifold, it doesnt really make a difference if it's closer or not.
I was saying to have a longer run between the filter and the maf, since it's got a 90° and 45° elbow between the two. Not exactly a smooth airflow across the maf. Lol
Thank you Gentlemen.
Wow. A wealth of knowledge!
Since she will never be the GTP...I think I have to accept her for what she is...but that doesn't mean lipstick on a pig is a bad thing.
I think the 'lipstick' for this will be the K&N filter, I will ponder the how and where from the info gathered here.
The trans tune, I will table.
You guys mention a 'tune', is this reprogramming the computer?
Thanks again, this was awesome!
She could still be a "GTP", you can slowly collect all the parts and mods you would need, install them one by one, then take a Friday off and use the 3 day to install the full top swap.
The tuning is computer reprogramming, the computer in our cars controls the engine AND transmission. Tuning will increase the performance of both, and is best to do with a laptop connected to the car itself, not just a "canned" tune from a company that mass produces them.
I think the trans tune you are referring to is the shift kit, it's fairly simple to do and will also preserve your transmission while making the shifts feel more solid and quick, not so much sluggish and meh.
There's other things that can be done, comfort, aesthetics, upgrades to certain systems, and the all important suspension and braking upgrades. Making the cat look good, feel good and handle corners like a boss is almost as rewarding as going fast. Lol
the shift improvement kit isn't all that hard to do. if you have a good mechanic that you trust it shouldn't take him more than an hour. it's just a little more intensive than a filter change, and if your transmission hasn't had its 100,000 mile service done, you could do both at the same time. as far as a tune, it is just a computer reprogram. some things that get changed are the shift points when the car is in power enrichment. the threshold for when the car enters power enrichment, you can also add timing advance if you are willing to run premium fuel, and that just by itself will make the car faster. There is a member on here named Overkill, his real name is Will, and he does these changes. I have worked with him to tune my car, and have been happy. the easiest way for you to do the tune would be to find another pcm from the same year of your car, make sure it is an N/A car, and mail it to Overkill, he will then load his tune on it, and then you swap it out with your existing pcm. this way you still have your original pcm and tune if you ever decide to sell the car, or want to put it back to stock for whatever reason.
I was trying to get him to stay away from canned tunes, Marshal...
Lol but Will knows what he's doing, that would be the only canned tune I will run in a GP.
Now if e talk canned tunes in general, it's better if you get the canned tune in the car when its new. Like with a 2015 car, there is almost no differences between one fresh from the factory and one with 10k, engine and trans wise. Less that could be slightly off in the canned tune.
A GP with 100+ thousand miles? So many things could have happened to that car, nobody can know how it truly affected everything.
Excellent, well thought out advice.
"...look good, feel good and handle corners...is almost as rewarding as going fast" Agreed. I'm not looking to go fast...I'm looking to GO. That 'sluggish, meh' is unacceptable.
Sticky wrote an excellent how-to on the shift kit. It is something I will consider.
PCM swap, too scary a job a weekend mechanic and for my daily driver.
I took apart air box to check fitting for K&N...found a mouse house in the forward box area. Cleaned the ****e out of the MAF and I'm pretty sure I got some giddy-up back.
Next, wires and plugs, thoughts?
Suspension is pretty lame. Those front sway bar links are toothpicks! So advice on shocks, links, bushings is appreciated.
Thanks again, enjoy the day!
Answers in bold for you...
Hello.
  1. 180* Thermostat - Why? Cooler? Any other bits of wisdom are appreciated. - Because even though without a tune, the highway cruising temps will still drop to 180*~. It helps to keep things a little "cooler" and not get so heat soaked. It'll help more so with a tune...see transmission answer as well; because if you do a 180*, with a drop-in high flow filter, a catted downpipe to open it up a little, the shift kit, and a tune...it'll really help the car out. Not much...but it'll be worlds better than it was.
  2. K&N Cone Filter - Is this just a matter of removing stock air box and slapping the cone filter in place? - Yes. All this talk of "smooth airflow for the MAF" is crap. Been there. Done that. Doesn't make any difference either way you do it.
  3. This GT seems sluggish after the GTP...no mystery there...feels like the tranny needs to shift later, like the 'Performance Shift' in the GTP. Is there a mod that a weekend mechanic can do to squeeze a little more out of the tranny? - Skip the shift kit; unless you want to screw with it. If you're in there for a pan drop and filter change; then do it. If not...get the car tuned. Regardless the tune is where the transmission comes alive.
Thanks! in advance.
If it was me; I'd leave this car alone. Rip the powertrain from the other one. Scrap it and find a clean body to swap it in and mod that. L26, unless going turbo...you're not going to benefit from anything on that damn thing. Hell a heads/cam full bolt-ons L26 probably wouldn't crack 225 horse to the tire. It's not worth the trouble. These motors just don't make power N/A for beans. OR; find a cheap turbo kit for it. That L26 will take a little bit...toothpick factory rods. It has been the weakest of the Series II/III 3800's across the board when modding. Trans will go if the motor doesn't...but if you top swap it, keep a stock pulley, toss headers on it with a small cam or some rockers...it'll be a decent street car: boost + high compression. :)
