impalamike3800
So I know a lot of you have at one time or another have had the amazing privilege of interacting with a member named 19se92. well I have made from various local threads that I am on (yes unfortionatly I have met him in person and believe me I never knew that the hunchback of notre dame was real either!) so here it is for your reading pleasure; the best of Ben Grieveson aka 19se92.
ClubGP Message Forum troubleshooting
Signal13.net .... Racing, Hangouts, Tech. - View topic - 00RedStang vs 19gt92
Signal13.net .... Racing, Hangouts, Tech. - View topic - Signals gettign bashed big time
Signal13.net .... Racing, Hangouts, Tech. - View topic - 3.29's FTW
Signal13.net .... Racing, Hangouts, Tech. - View topic - 2002 Grand Prix Gt Vs 1997 Grand Prix Gt
Signal13.net .... Racing, Hangouts, Tech. - View topic - Callout - Ben
Signal13.net .... Racing, Hangouts, Tech. - View topic - Should 19se92 Be banned?
Signal13.net .... Racing, Hangouts, Tech. - View topic - CHECK IN BEN
Message subject: Re: SS M90 Kit
Folder: Sent messages
19se92 wrote:
this is no bull**** dude. I'm reasearching about the top swap and the SS Kit You went ss right?? If so do you mind telling me how much the kit cost you total. And did you use the zzp fuel logs or not?
Thanks
L36 SS M90 Install Kit - $355.00
Year of your car
1997
Model
Grand Prix
Option 1
Regulator & iron bracket (+ $45.00)
Option 2
Send me a PCM first $100 deposit (+ $110.00)
Option 3
42# injectors
Modular pulleys
VIN :
Size:4.2 for SS kit
Color:Black $69.99 $69.99
Eaton Rebuild Parts
VIN :
Model:M90
Option 1:Seal + snout and needle bearings $89.99 $89.99
Heads
VIN :
Model:Stage 2
Color:Black
Core charge:GT heads $1,199.99 $1,199.99
Short Stack Intercooler
VIN :
Model:Gen 3 M90
Option 1:Flojet pump
Option 2:Heat Exchanger
Option 3:Injector spacers $679.98 $679.98
Supercharger Coupler
VIN :
Option 1:2 GM S/C Oil 8 oz.
Option 2:Add coupler swap kit $59.98 $59.98
Eaton bypass valve
VIN : $39.99 $39.99
Ported M90 Supercharger
VIN :
Year of your car:98+
Core charge:Case only core charge
Option 1:Mod'd for use on SS L36 kit
Option 2:7 oz of GM s/c oil $385.00 $385.00
EATON M90 Snout
VIN :
Model:New Eaton unit
Option 1:machined for sub 2.8" pulleys $290.00 $290.00
Ported & machined lower intake
VIN :
Engine:Gen 3 blower (L67)
Model:SS intake for L36 M90 conversion
Core charge:Core w/ prepaid return label
Option 1:Add Intake Gasket
Option 2:Add runner porting/gasket match $438.00 $438.00
ZZP BILLET FUEL LOGS
VIN :
Model:L36 SS M90 kit $454.99 $454.99
Billet 78mm throttle body
VIN :
Option 1:MAF hole closed on TB $349.99 $349.99
GM 85mm MAF Sensor kit
VIN :
Year of your car:'97 to '03 $125.00 $125.00
Throttle Body Spacers
VIN :
Model:97-03 GTP/GS/SSEi $44.99 $44.99
Fuel Pump rewire kit
VIN : $34.99 $34.99
42.5# Lucas Injectors
VIN :
Option 1:8 injectors
Option 2:Injector connectors
Option 3:Send me a prepaid return label $364.99 $364.99
Sub Total: $4,982.87
this will ensure perfect running car and will take you into high 13s.
Sent at: Fri Nov 07, 2008 11:42 pm
View message
19se92
Message subject: SS M90 Kit
Folder: Inbox
Thanks
Sent at: Fri Nov 07, 2008 1:56 pm
View message | Post a reply
Message subject: Re: Callout - Ben
19se92 wrote:
I see trying to be a smart ass which you failed at. Mike you fail at everything man. Please do us all a favor and STFU you'll never be as smart as me in the automotive field. So please take your bull**** and go jump off a bridge. Oh I did not need school I taught myself dickhead.
What have I failed at? name something. and do not say everything. I want to hear what you could throw at me within the year that youve known me.
Ill be waiting.
Sent at: Fri Nov 14, 2008 3:28 pm
View message
19se92
Folder: Inbox
Sent at: Fri Nov 14, 2008 3:04 pm
impalamike3800
19se92 wrote:
you won't pass trust me and your a sears tech not a true master mechanic
your right i am a tech at sears, meaning I am in the feild, do i plan on staying there? No. I plan to move on to bigger and better. I am 3 years younger than you and have accomplished more than you will ever. I have a 4 year degree in mechanical engineering, going to PTEC so I can further my knowlege about automotive (as well as get another degree in Industrial Management). So sling your puny ass arrows at me; because no matter what, I AM JUST BETTER THAN YOU PERIOD. In both life and in education.
Do not bother attempting to rebutle me because I am done with you. It will just be better if we do not continue talking because I have grown tired of this silly banter back and forth. So this is it.
Goodbye Ben.
Sent at: Fri Nov 14, 2008 12:29 pm
View message
19se92
Folder: Inbox
Sent at: Fri Nov 14, 2008 11:24 am
impalamike3800
19se92 wrote:
its easy if you know what your doing and how to mod unlike you and andy and Corey
rrrrrrriiiiiiggggggggggggghhhhhhhhhhhttttttttttt. that is why I am a mechanic and going for ASE certification in brakes and engine performance this month. cause I do not know howto "mod" a car. well I will tell you something benjamin, I bet you I have more automotive knowlege in my pinkey toe than you do period. you know what just do me a favor and do not bother continuing this conversation. i am done with you. this is apparently going nowhere. good luck hitting 12s with a M90 and a grand.
Sent at: Thu Nov 13, 2008 3:03 pm
View message
19se92
Folder: Inbox
Sent at: Thu Nov 13, 2008 11:06 am
impalamike3800
19se92 wrote:
its called ed morad mother ****er.
and guess what... ED SELLS STOCK PARTS!!!!!!!!! dumb ****. but hey you know what if you hit 12.9 with just a top swap then the 3800 gods must love you more than anyone else because they will be allowing you to defy several laws of physics.
Sent at: Thu Nov 13, 2008 2:22 am
View message
19se92
Message subject: Re: Callout – Ben
Folder: Inbox
Sent at: Wed Nov 12, 2008 4:51 pm
impalamike3800
19se92 wrote:
Its called the true top swap dude. I was against you all because you all didn't research like I have But I bet you did mike so its all Good. Lets just saw I'm studding the heads and getting the swap from Ed and I'll be in the 13's maybe 12's for just over 1k when all said and done.
so you mean to tell me that Andy and Corey did not do true top swaps? well oh marvel of motors, what was it that they forgot that you will be adding and how the hell 12s would be possible just over a thousand dollars. you going to gut the entire car? you going to go on a diet? As for my setup, I listened to both Andy and Corey. They have knowlege with blown L36s and they did their research. Its called trial and error. you need money to do it. Andy never got a 12 second time slip and spent a few thousand on his Monte Carlo. Corey had a head gasket go out. nothing big and had nothing todo with his setup. **** his was 10 times more mild than Andys and that happened. Hell an intercooler will cost you over a grand as will a built transmission (unless you rip someone else off) so that is closer to $3000. So check and Mate *****.
and for the love of God, USE ****ING SPELL CHECK!
Sent at: Mon Nov 10, 2008 8:58 pm
View message
19se92
Folder: Inbox
Sent at: Mon Nov 10, 2008 5:45 pm
pm to a local member:
I've researched the Top swap Months prior to me getting my 2002 gt Fred. I got everything planned out and a couple of tuners lined up so I know I'll get well over andy's s/c'd monte did for power and I saw it yesterday in npr. Here's a taste of the top swap mods when finally done..
mps system 3.8 3.4 3.25 2.76 2.55 (nasty time pulley)
ssic intercooler
n* ported tb
headers
xp cam
3in exhaust
tune
1.9's
hd trans upgrade
# 42's or maybe 60's
you get the drift dude I got my **** together unlike andy and corey did. Not trying to be a dickhead or anything. And there is a 97 gtp in the polk city area that runs almost the same setup and can walk older vipers from a roll
To: ordonez1307
Date: 1/28/2009 12:39:24 PM
Subject: DIE
can you die for me you little piece of ****. I would like to see you again I got a ball bat with your name on it and OH yea read the ps in the post by twinrotor HAHAHA your ****ters still down. So *** off Faggot.
From : 19SE92 To : impalamike3800 Date : 8/12/2007 11:13 PM
Subject : **** off
you talk a big game over on mafia so why not here??? i had mad respect for you but when i joined mafia and you started talking all that **** i lost it do you see me going around talking mad ****??? so all i got to say to you is **** off and grow up and pass this on to andy and fred as well
Thanks
Year of your car
1997
Model
Grand Prix
Option 1
Option 2
Option 3
42# injectors
Modular pulleys
VIN :
Size:4.2 for SS kit
Eaton Rebuild Parts
VIN :
Model:M90
Heads
VIN :
Model:Stage 2
Color:Black
VIN :
Model:Gen 3 M90
VIN :
Eaton bypass valve
VIN : $39.99 $39.99
VIN :
EATON M90 Snout
VIN :
VIN :
VIN :
VIN :
VIN :
VIN :
VIN : $34.99 $34.99
VIN :
View message
19se92
Folder: Inbox
Thanks
Ill be waiting.
View message
19se92
Folder: Inbox
impalamike3800
Goodbye Ben.
View message
19se92
Folder: Inbox
impalamike3800
View message
19se92
Folder: Inbox
impalamike3800
View message
19se92
Folder: Inbox
impalamike3800
View message
19se92
Folder: Inbox
ssic intercooler
n* ported tb
headers
xp cam
3in exhaust
tune
1.9's
hd trans upgrade
To: ordonez1307
Subject: DIE
Subject : **** off
