    TIPS:
1997 Pontiac Grand Prix GTP Turbo
my97gtp
I have a 1997 Grand Prix gtp that is turbo for sale. It has a lot of aftermarket parts and runs but has a spun bearing in the lower end of the motor. I am in the process of selling my house and cannot part it out right now so am looking to sell as a whole. It needs a battery as well but I had it running and driving a few weeks ago when I found the bearing issues. I have the parts listed below. The car had about 116000 on the chassis. The motor had about 80k and the trans and turbo kit have about 10k. I am looking for 1800 Obo. Car is sitting on nitto 555r in front. The matching eagle 077 wheels for the front are in the trunk but needs tires. For anyone that would put less than 1k in this car will have a real beast on there hands. Is tuned for 12-14psi on a l36 block. No track or dyno times on setup. Car is located in Columbus Indiana. With a jump car will run and drive short distance.
Please email me at [email protected]
Mods:
prj tuned pcm (9/28/2013)
zzp 2750 stall convertor (11/4/2010)
st3 cam (3/10/2010)
130lb springs (3/10/2010)
roller master double roller (3/10/2010)
Built transmission w/shift kit zzp input shaft (10/20/2007)
3.29 single chain gears (10/20/2007)
60lb injectors (6/8/2007)
turbonetics 62-1 hifi (4/16/2007)
zzp z6 turbo kit (4/16/2007)
power log front ported and turned 6th rear manifold (10/13/2006)
afc 2.0 (6/16/2006)
180 tstat (6/15/2006)
diy a/a intercooler (6/15/2006)
snm motor mounts (3/15/2006)
103 plugs (1/2/2006)
zzp turbo pcm (10/29/2005)
Looks like around 500-600 could possibly have a work acquaintance do it for less but would have to check. You interested?
