What's the pressure I should see in my AC
01grandpri
2002 gtp . What pressure should I see whe. I put my gauges on the compressor. When running that is..anyone know?
25-45 is the normal low side pressures, which is what you will mainly use for filling per pressure. 25 would be on a cool dry day, and 45 would likely be a very hot and humid day. You can find charts for temperature/pressure.
I looked on google and I couldn't find it.. I live in Michigan during the summer it's very humid..
crazy guy do you have A/C equipment? vac pump, etc?
I installed a new condenser but need to do a leak down test.
Maybe ill load in some dye and pressurize it, the dye will look like a murder scene under black light if there's a leak,
yessir I do
