Any secrets on taking out 97-03 seats?
front or rear? pretty simple in front. remove 2 botls, slide seat back then up and out of the holders and bam, slides out the door. Rear have tabs under the cushions to pull. there are 2 under the cushion close to where the front seats are placed.
Its really straightforward. The front seats are hooked into the floor at the front, you'll see. Don't forget to unplug the wires under the fronts, first thing.
Just a few bolts then?
2 15mm bolts in the back along the track. Remove both of those. Then slide the seat all the way back and make the seat fold forward as far as it can go, and push down the headrest all the way. Then tip the seat forward and lift up. May take a few tries, but you'll get it out. Remember to disconnect the sensors and stuff under the driver seat.
