SgtMarshal
Active member
The 2.93 chain set is supposed to be stronger
What does a stock boost gauge look like in your car? I haven't seen one on any 04+ cars. With a 3.8" pulley on a stock car they will make right at 10psi.
Jeff
your thinking this is a numbers matching car???? that just dont exists no more, thats a 70's and later deal.
back in the day you could break down a vin, but thats long over. its who cares ville for these cars really.
Your RPO codes should tell you what motor, trans, suspension package etc etc etc, the VIN will mainly be for year and where it was made.
There are no tags on the tranmission to tell what gear ratio it has but the HD transmission have a different diff cover than the non hd transmission. I can't find the picture of the difference at the moment but you can look up both transmissions on the web and see the difference. (the diff cover in where the passenger side axle goes in).
Also if you have paddle shifter buttons on behind the steering wheel, it's a Comp-G with 3.29's. Highway revs at 70mph is roughly 2200 aswell compared to the 2.93's that are 1800-1900ish.
there are trans tags on the 4t65s its on the back in just a little farther than the diff cover. in the vehicle its facing the rack and pinion.
you can decipher the stampings on the trans with this
http://www.gmtuners.com/pda/4T65E-ID.htm
that shows what vehicle it came out of the tq convertor size and trans id code.
if you need to find a compatible trans for a certain vehicle.
edit btw the hd diff does not effect over all gear ratio. you could use an hd diff on any trans so long as you use the correct hd cover.
the above info is wrong........
here is how to break down a trans id code.... lol they do indeed exist....
https://www.google.com/search?q=4t6...AUICCgC&biw=640&bih=280#imgrc=b6g-33XSjuqrTM:
Check the rpo codes underneath the deck lid (trunk)
Sent from my KYOCERA-C6745 using Tapatalk
It's in the DIC. Just a bar that extends from left to right the higher the boost goes. No numbers on it. Kind of useless if you ask me. Along with all the other gauges. You don't see speedo's that don't have numbers on them. Why doesn't the temp gauge have numbers?
I guess you have the 5 button DIC then, my 05' GTP has a 3 button so I installed a boost gauge to see what was going on. When you said your 8th digit is 4 that is the 3.8L SC engine I'm not sure where you got that info on a 4 cylinder it was never even an option on these cars (04+). The RPO codes are under the carpet in the trunk. As far as the temp gauge goes it's standard 100-260F (38-127C) gauge it just isn't marked. Typically the temp will run between the 1/4 mark and the center with it going a needles width over the center about the time the fans turn on (217F,103C) low speed.
Jeff
