lilrunna4me
I've been battling this issue since November of last year and I'm out of ideas of what could be wrong. The coolant hose rubbed up against the belt and caused a big gash in the hose. At first my car would stall after I would come to a stop without any warning, then when I started it up and shifted to reverse the car shut off, now where it won't even turn over anymore. I've changed the fuel pump, fuel filter, and tested the fuel injectors and they are fine. Also used a fuel system cleaner and sea foam on the car. The car only has 90,000 miles on it, Any ideas would be great thank you.
Update: Just changed the crank shift sensor, got the car to move up and down the street but went down a slight hill and it stalled when I came to see stop again without any warning, I also noticed some of the fuses and relays look Slightly brown. But none are ones that would cause stalling, I believe. Picture below.
Sent from my SM-G386T using Tapatalk
Sent from my SM-G930T using Tapatalk
