Did an oil change yesterday. While I was breaking the drain plug bolt free, a few good harsh yanks - the rear of the pan seemed like it was moving. I do notice some oil around the oil pan bolts and the majoirty of the oil seems to be around the side where the drain plug bolt is. Can these bolts just be loose? Would that cause the oil pan to move? It was the rear of the oil pan around where the drain plug bolt is. That whole side was flexing. Can I tighten all the oil pan bolts or do I need to remove stuff? Can I use some blue loctite?
I've done my valve cover gaskets and grommets, etc.
02 GP gt, 199k, 3.8 series 2...
