ABS light
onklp
Hello i have a little problem my ABS control light is coming on when i turn on my ignition this one what supposed to flash couple times and go off after i start the car i checked the fuses and they are ok ,but i also have a problem whit tire pressure sensor on right wheel its not showing the pressure is ABS is connected to TPS car is 2007 GP base model
ABS and TPMS are not correlated. TPMS sensor is probably dead. ABS could be bad bearing, bad speed sensor, or frayed wire.
But the ABS light is not even on thats the problem because it supposed to light up when i put key in ignition and then go off after some seconds
hmm problem solved as it comes to Base GP models ABS in 2007 was an option so my car was ordered whiteout ABS brakes
