Dave's Saab Story 2.0 - TRANNY SURPRISE!
Re: Dave's Saab Story 2.0 - Bill called me while I was humping...THE WIFE
Car is dirty as hell...haven't washed it all winter.
BBK, new suspension stuff, some fixes...all going in April 30th
Time to update the sig, or paint the roof rack brown in your current one lol.
This is some real euro trash **** lol
Nice looking SAAB Dave, I like the way the bra fits you.....winter mode?
Did you score a new Ford?
Mmmm rpf1s. Been thinking about getting those in 19's because they're so light.
Sent from my SM-N910V using Tapatalk
**** I'm replacing on the Saab next weekend:
-Front wheel bearings
-Drivers front speed sensor
-Front rotors (upsize to 315mm EBC Slotted)
-Front calipers to 4 pot brembos
-Lower control arms with Poly bushings and Moog PS balljoints
-Brake lines to stainless steel
-Rear calipers with new ones
-Rear rotors (EBC Slotted)
-Rear subframe (new one coated to not rust)
-Rear upper control arm (new one coated to not rust)
-Rear lower control arm (stronger and adjustable)
-Rear trailing arm bushing to Poly (I have poly in there now, but they are chinese knockoffs that failed)
-Rear sway bar endlinks (Moog PS, poly filled)
-Heat tape wrap delivery pipe
Maintenance I'm doing:
-KBS seal coat and Rustoleum oil based rubber coating
-Coating the exhaust black
-Replace spark plugs
-Clean the MAF
-Replace one check valve on PCV that failed
-Replace air filter
-Replace CPS
This car is ****ing rolling on an entire new suspension down to even some of the hardware that holds it all together...wtf is wrong with me.
Things I need to do also to make the car 100%
-Pull fuel pump and remove lose baffle (common problem, gives false gas gauge readings on occasion)
-Fix two rattles
-Replace driver's seat bracket because it has a tendency to shift under acceleration and braking
-Replace roof antenna
Not sure when I will get to the other 4 things, but I have a ton of little stuff like clean the tail light connectors and dielectric grease them (age sets in, BMWs use the same connectors and have the same problems) and checking the wiring under my dash and neatin' things up a bit.
I still have a short throw shifter and custom pedals to install, I plan to do them while the drivers seat is out. I need to rewrap the vinyl on the roof as it is about 3 years old now and starting to let go, so I will probably do the antenna at the same time and drop my A, C pillars and headliner to wrap them in a custom cloth I have. Then it is onto the motor/transmission build and a revamp of the stereo while I am at it.
I did somethings, like rebuild calipers and built my LCAs
Detailed a car
And parked next to a corvette
and another saab
If I have someone in the back seat, the rear wheels will make contact with the liner ever so slightly on a hard bump (deciding either more camber or roll it a little) and the front rub a little nub that sticks out on the liner, I'm thinking I will let the car burn a hole in that, then buy new ones. I'll heat up the liner nub and invert it the other way.
Tell the passenger to walk. I don't really let people in my car.
And your license plate made me laugh, because I always yell WASABI!! to a friend at work lol.
So, its been a busy few weeks. Just took a trip to Carlisle, PA and put over 1000 miles on the car in 3 days. Only a few things need attention; rebalance wheels, new windshield, and roll the rear fenders.
Visuals
-Matt D Turbo X Front lip
-Black painted center lip on Aero bumper
-3000k HID fogs with Yellow tint
-Smoke Metalcast Grilles
-Natural White LED City Lights
-Sylvania Silverstar Front and Rear turn signals
-Philips XtremeVision 5000k HID bulbs
-Hood Bra
-35% tint
-Gloss Black vinyl roof Wrap (soon to be matte)
-Custom made Wood Roof Rack
-In Channel window vent visors
-Spoiler King rear window spoiler
-Natural White LED License plate lights
-Custom Aero badge on trunk
-KBS Undercoating
Where you sit
-Infinity Kappa 32.9cf dash speakers
-Llyods 5 floor mats with Saab logo
-Second skin audio sound deadening in dash, front and rear doors and rear deck lid (soon to be roof too)
-Custom made leather/suede steering wheel
-Ultimate pedals custom pedals (not installed)
-Genuine saab short throw shifter (not installed)
-Kenwood DDX372 stereo
-Backup camera
-Blue/yellow stripped door sills
-Warm White LEDs in every spot (Map, dome, reading, foot well, puddle, trunk, and vanity mirrors)
Go Fast
-Open air intake
-06+ TD04 with king cobra
-BCB 3” downpipe
-OBX 2.5” catback
-BCB Stage 3 Tune
-Custom Grounding kit and direct wire to alternator
-BCB Diverter Valve (Heaviest spring)
-Powder coated valve cover (visual
-King cobra and u-arm motor mount mirror polished (Visual)
Hold me to the road
-Koni FSD
-Hirsch replica Eibach springs
-Proparts front subframe bushings (Soon to be powerflex)
-PowerFlex Lower control arm bushings
-Moog uprated front sway bar endlinks
-Moog Poly rear sway bar endlinks
-SAS Sway bars front and rear
-Poly bushing torque arm
-PowerFlex trailing arm bushings
-EBC Rotors
-EBC RedStuff pads
-Goodrich Stainless steel lines
-Krona tower brace
-Enkei RPF1s 18x8 5x112
-Michelin Pilot Super Sports 235/40/18
Subframe removal
Undercoating
Putting it back together
Pretty sure these are shot
Front stuff
On the road for a trip
Home again after 1000+ miles
New windshield next weekend and then rolling the fenders. I hope to install 4 brand new calipers soon and get the front wheels rebalanced (hopefully thats the vibration I'm feeling). The roof wrap has been on for 3+ years and its starting to fail, so it is time to rewrap the roof and I have a short throw shifter to install.
Washed and waxed the car today.
Thinking about powder coating the wheels in bronze.
Trying to find a shop to embroider the headrests.
That is about it.
I like the silver on the rims myself. Car's looking great, never thought I'd really like a Saab lol.
Your projects are always interesting Dave.
But come on, wash and wax? I think you are talking in layman terms.
I like silver too, but the car is silver and I think I need a little contrast.
This is the bronze color I'm looking at
Well everything has been good with the car, drove it 1500 miles and the only issue I have is the one front sway bar end link gave up on life and it clunks right now, otherwise the car is kind of sitting pretty with no issues. If I had to gripe about anything wrong with the car is the Driver's seat shifts a little but I have a new bracket for it and the one headlight washer lost its mister nozzle and I have a new headlight washer that just has to go in (but I avoid using the headlight washers anyways). No zip ties here either, everything has a bolt. Guess I went boring LOL.
As far as future things go, it all depends on the baby situation. The wheels are definitely getting powder coated, I have a few more interior mods I would like to do but I've sound deadened everything and I have zero rattles from anything. And the big ticket items are the motor and transmission, I'm still playing with the idea of building a motor for more power but that is some serious $$$ that I feel may not make into this car :/ I haven't 100% decided yet. If I could find a good junk car with both the motor and manual transmission I need, make the money back and fund the build with the parts of the car, then we are in business.
There is also the idea of changing the color of the car, I've been getting good with vinyl wrapping and I'm thinking about giving it a go. Not letting it out of the bag as to what color, but it is a pearl.
I sold the BBK that I pieced together, the rotors that I had for it were 10lbs heavier per rotor over what I had. Just seemed to be not worth it because of the added mass, so I am working with the idea of doing wilwood calipers on the stock size rotors. But for right now, I have 4 brand new calipers and SS lines that will make its way onto the car this weekend.
Have you thought about temporarily plasti-dipping them?
I had a buddy who was going to powder coat a certain color, so he dipped them first. He ended up not liking the color once they were on the car, and went a completely different direction.
