wifes car had a brake line blow out above the fuel filter in the rear.
I ended up buying all new OE GM fuel supply/return/vapor line and went with this place for the brake lines.
https://sstubes.com/vehicle-manufacturer-pontiac-passenger-car#/specFilters=43!#-!650!-#!25!#-!361
stuff came in the mail yesterday and is legit. Stainless is what I went with.
In the process of tearing out the old garbage, so far have everything disconnect in the rear by the fuel filter. the plastic retaining support clips are tricky but was able to save all of them so far. Also the fuel vapor quick connect fitting was a real treat to get apart.
But tonight I am going to disconnect the lines from the ABS module and start wiggling everything out of there. My hope is that I can weasle the old lines out and weasle the new lines in without too much hassle.
Worst case I was going to remove the sway bar and if needed possibly drop with subframe 2".
I am planning on not putting any unions in the system (except for the passenger rear, SStubes already has one) and making it a clean repair job so I don't have a headache when I go to bleed and fire up the fuel pump.
Wish me luck and I will take some pictures of the old lines, new lines and hopefully the trick to slip these new lines in without much trouble.
