1999 Regal GS Turbo failure...
Re: 1999 Regal GS turbo install underway
I wonder why no one's just put a throttle body on the snout block off plate and just block off the OEM supercharged throttle body.
Re: 1999 Regal GS Turbo with coils now installed
Small update. Most of the hotside is installed. The m90 block off Is done and I'm working on intercooler fitment. Hopefully I can finish up by Friday/Saturday.
I seee a red top in there!.....lol!
Because you cant just cut a hole mount a tbody and call it a intake. If it worked like that everyone would have a properly functioning intake manifold.
Another update. The regal is running and driving. I had a couple issues here and there with clamps, couplings and vacuum lines but it seems to be worth It. The car is way different now in a good way. Now I can start tuning once it learns the fuel trims from my base tune
Re: 1999 Regal GS Turbo powered now!
They are loose. I think I just jammed them down there when I was putting the fuel rail back on
Absolutely not lol. My injector pw was at 25 or so at 43% throttle. I might be switching back to pump gas until I can buy some 80# injectors
I thought your pulse width was supposed to be lower than 20. how is your afr?
you try upping the flow rate of the injectors at all? or you just tried one value so far? i was to high on my value's and flooded the hell out of my engine good, wb pegged at 9 as low as it goes.
I've got a catch can and a turbo snuggie on the way. Underwood temps are too high for my liking
