Power steering low and high lines
if the line moves while driving over time the hard line will rub a hole in the rubber hose. you can get some more hose, cut it open like a hot dog bun, put it over the hose and zip tie it on there, this way its rubbing the insulator hose you installed not the important one.
O really? Why?
Chafing. Looks like they zap-strapped the two lines together. i'd put some plastic loom on the rubber line, just like the one next to it. Or if you have some larger hose, cut a small piece, cut it open to make it "split" and put over the hose in question.
K thanks guys will fix the hard lines touching and the rubber one. Would plastic loom work fine for both or even a piece of a garden hose? Does the stock lines also touch like that?
Sent from my SGH-I337M using Tapatalk
