Swaping engine and trans from top ( first timer)
I was hoping there would be a bracket there that would explain the engine shake. A friend of mine who has a code reader wont be back till mon. Im wondering if i should go to hf and pick up the 40 dollar one.
you check the trans fluid yet while it running? fill it up if needed? get that done and drive it to the parts store, autozone scans for free.
you got a miss fire causing the engine to shake, not the bracket that kyle is now saying is not there. more stuff on the floor to look for lol
what do you mean by misfire Scotty? how can i fix this i made sure wires were in the right order and they weren't damaged as far as i could tell.
Heres another symptom the car shakes more when i give it gas but then smooths out after about 1000 rpm
Also i got gallon of antifreeze 50/50, about how much more will i need?
one more, then some water to top off.
the way its stumbling is a misfire. two crossed plug wires will do that, its easy to fvck them up, so go check once more.
it could be a injector thats not firing. you can swap the fuel rail and injectors from your old engine, cause we know they worked.
but the code will tell us exactly whats going one.
ok gota get more coolant then im driving the shakey beaut to autozone
nvm..they dont read codes here in ca, we've got all the best laws
Oops. Didn't see your earlier post lol. Those 2 bolt holes are for a different model car. My bad lol
Sent from my LG G3
which two bolt holes? th ones on the bottom left or right and corresponding to which car? i have a pair of holes on the bottom left and right. the right holds a bracket the left is??
i trippled check the wires too and they are right. I guess ill have to spend on a code reader from hf.
