silenthaven
So im unsure if I should go with zzp solid rubber trans and engine mounts or the poly ones. I plan to lower the car an inch or so in future and just dont want overwhelming amount of vibration. Also im getting shorter dogbones.
Shorter dog bones do not correct the axle geometry that you are wanting.
You need to space the motor and transmission back up to correct the angle.
Soild rubber mounts will work prefect.
Yea you can use the shorter dog bones before but I wouldn't use the spacers tell you do the drop
Sent from my SM-G920V using Tapatalk
