I think the power steering lines might be hitting the bottom part of the rear exhaust manifold. Is there something heat resistant I can wrap them in that will dampen their vibration?
The only thing that comes to mind are those spark plug sleeves. Maybe wrap those around the power steering lines to avoid heat transfer.
id bend the line out of the way a bit.
all my lines and sway bar looked pretty close too. i put some masking tape on areas that looked like it maybe hitting, the tape would show if any even light contact was going on. nothing was hitting.
Not a bad idea. I'd have to cut the sleeves and glue them out clamp them to hold them on. I might have a bicycle tie to use for the dampening
