Jason97GrandprixGT
Car is back running like a champ thanks ppl
Sent from my SM-N910T using Tapatalk
How far should I bring it up because my car doesn't shift normally because of itcruise control cable, and your dont adjust it.
Lol I'm going get it scanned now my mandoes that cable lead to the tranny? if so all it does is pull it in or out of gear, has nothing to do with sifting down the road.
once again, its not adjustable. the clip on the end can break, but that only affects it going into gear. or not going in gear or into park.
if you would only get the car scanned. you'd have a good idea where to look. but telling you that is like beating a dead horse.
Can you circle and name the cables in the picture for meThere's three cables in your pic.
Throttle
Cruise
Trans
None of them would directly affect shifting as long as gear selection works.
Just left autozone no codes popped up when they tested itbest news ive heard in days. lol
The degree of my intake could cause stalling?Maybe the degree of your intake is incorrect.
The maf is oem and I put black tape over the wires. It's not dying on me like it did before but my car would still stall a bit after I come to a complete stopodd cause you say the check engine light never comes on.
the bare wires at the speed sensor. you fix them? that could be the issue.
or that aftermarket maf too. these cars HATE them big time.
I spliced the wires on with the new vss connector and wrapped it up with electrical tape. My abs light remains on now I'll go back over it tomorrow and get another connector from the junk yardtapes not a fix, you need to cut the wires back till you get to clean shinny copper wire on both sides of the damaged wire, then solder in a new length of wire if needed to make up for the wire you took out.
if its bare to the plug, you buy a new pig yail and solder it on.
Ok also the vss connector on my car is different from other vss connectors from other cars like impala and monte carlo with the 3.8 engine. Why is thattapes not a good for a seal. it needs to be soldered and sealed with shrink tubing so its air and water tight.
