Tonkin2000GT
thats reading the o2 sensor, aka narrow band. its just not the same.
What's a good wideband gauge? Anyone have one forsale? The problem is I don't have a spot for it in my 3 pod I already have 4 gauges in the car.
not the same thing. its reading the actual air fuel reading out the down pipe. with its own wideband o2 sensor.
The interceptor gauge reads what the PCM reads which is in Millivolts. A wideband has it's own controller, and readout so that you can see what your actual AFR is. Different brand O2 sensors will most of the time read different outputs. Which is why if you have a wideband that's a good calibrated setup, will tell you where you're at.
Not really when everyone tells you something different....
It's because those people don't have ther own tuning software and have likely never used a wideband.
I've seen guys with $60,000 caddys ask why they should need a wideband sensor after they have already dropped another 5 grand in mods on the car. Like it never even dawned on them that they needed to watch this kinda stuff when you are making 700whp.
ZZP isn't well liked around here for these kinds of reasons.
