ZZP trailing arms or BMR trailing arms?
Tonkin2000GT
I was wondering what is better? ZZP chromoly trailing arms $120 or BMR steel trailing arms $100 but they are huge 1.5" with grease fittings.
BMR... Are like $90-100 on eBay.. You'll spend more then that getting arraur version
I am not a big Fleabay user, but have been humbled by your teaching me something new... Omg, for $90 I may just upgrade to the BMR's Lolz (have arraut's currently)
Those BMR's used to be a fortune... Lol
anyways, to the OP, go with the BMR's definitely for $90... Huge and stiffer in the rear is better!
(hahahaha, that really doesn't sound right)
You can see the difference. I believe arraunt uses the same steel tubing for both there trailing arms and lateral arms
Obviously you better make sure clearance isn't a issue
They're much bigger then stock.. Meaning depending on what wheels you run.. Offset/tore size could be a issue
