Lonely bracket
tuononero
Hi again.
I'm rebuilding my engine finally after a week of rain. I started the engine after i changed the heads and all the gaskets. It seems to run fine for now, i'll put it on the test very soon.
Now i have some other problem.
I found this bracket and i totally removed from my head where it goes to. Probably it goes on the back side (back header) but i'm not sure.
Any hint on that?
Thanks
well its a weight reduction if you dont put it back on. also keep in mind you may have 2 of the same brackets and are not paying attention
I think you are referrig to the two attachment points for the hoist, one in in the front and one is in the back. Those i have back on. I also have the support for the plastic cover. The only one left is this one and i really can't remember where it goes. But if it's useless i'll keep it out.
Passenger side dog bone engine bracket. So its the bracket which supports the dog bone engine bracket if that makes sense. Pic attached, with the dog bones removed.
attachment.php
