2005 Comp G Acceleration Hesitation Then Jolts Forward
Blake71091
My 2005 Comp G hesitates to accelerate when I floor down the pedal or give it good pressure. Then it will all of a sudden jolt like its catching/slipping gears. Does it on free way from 60-70 and around 20-40 mph.
When I have my cruise set I can hold the 'Accelerate' on the Cruise Controls and it will accelerate just fine.
MAF?
Was reading some things about the TCC or a PCM Upgrade?
Thanks
Clean your maf and throttle body. See if that fixes it
Sent from my SAMSUNG-SM-G920A using Tapatalk
Cleaned MAF and TB thoroughly. Air filter is new. Seafoamed the fuel system. Same problem persists.
When I floor it on freeway hesitates for 1-2 seconds then suddenly jolts forward. Feels like a very hard shift.
Does the same exact thing on city streets ranging from 30-50 mph. Theres always a short delay unless I feather the throttle.
Occasionally from a stand still to 2nd gear it won't shift until 3000-3500 rpm.
Recently dropped the pan and filter. Could I have added too much fluid? Fluid level:
Just replaced both front hub assemblies. FR threw a code again after replacing but goes away. Shows up maybe once a month or more, but resets when I turn the car off and goes away.
P0300, but no CEL. Erased all codes hasn't came back for awhile.
So no codes at the moment.
