glanzergtx
I'm having an issue with a 00 GT starting. It was top swapped a few years ago and had a rod bearing go out. So I put a L36 back in it and kept it NA. I swapped the map sensor back and wrote a new calibration for a L36. I have fuel pressure (55 #) and have spark. Something I'm curious about is the map kpa is at 170 and won't go any lower. Could this be the issue? I also have not checked compression. But this was a running motor when pulled. It came out of a bonneville are the crank sensors different?
