Okay. Swapping to a non ABS can't be all that hard I wouldn't think. Would I need a new master for that?
Also jd, do you think the Fbody intake is worth it? I have 2 sitting around I'm about to to throw away but I've thought about using one for the turbo setup. I have the LIM, UIM, TB, and the fuel rail. Just wondering if it's worth the hassle of relocating the battery and making the upper hose work
I like it a lot... only for the fact that you don't have everything crammed in one spot.. Having the TB over on the other side gives you some breathing/working room on the driver side.
Performance wise its debatable, but the fact it makes it easier to work over there was a big plus to me.
I used the L67 TB. Just hogged out the fbody intake for about 5 minutes to match up a bit closer.
Gotta move the battery and get creative with the fuse box and junk to make everything clear.
Doink with the radiator hose. We cut and rewelded our original tstat housing to be a bit better position, made a bracket to run the hose around and under the coil packs.
Its some work, but nothing all that major really.
Did you have to order longer throttle cables or what?
My wife's 06 has no abs
I wonder if you could use a different master. If you could use one from the base 06 that doesn't have abs and be ok. Would have to do some custom brake lines but that's no biggie.
It's the same as the '04-05 base model's as well.
They had no-ABS options, and they're cheap, too. Just grab one of those if you're wanting to keep it clean.
That is what our plan is with the black coupe.
All of this talk about stopping...and I can't believe nobody's thrown in just using a parachute.
