Those of you with a Stattama/3" DP...
PurpleGuy
The car this setup is going in is a 97 GTP. I've read I need a smaller brake booster. That's no biggie.
I've also read I might have issues with the ABS block since it's a 97. Anyone ran into this or can shed some light?
Thanks
EDIT: Found these pics of Alex's car. I talked to Alex about it about a year ago and he said he deleted the ABS but the ABS is there in these pics so maybe I'll be okay? These are the same pics in post 35. I added them here so they're more likely to be seen.
if your abs pump is bolted to the master the 4 hard lines may not like being moved to far. you know old and rusty.
Right. I'm just curious if the downpipe will actually fit. And if it doesn't what I have to do about it wether it's convert to newer stuff or delete the ABS all together although I'd rather not do that.
from pics ive seen its the master end thats close to hitting. the Monte booster is supposed to make it clear better.
Unbolt it, move it to where it will fit, rebolt it.
Your going turbo, break out your common sense and problem solving skills!
id like to see how one pulls that off in a 97/98. the abs is bolted to the master, and the abs has 4 lines off it.
looks like this.
