I hope not, it's a brand new Interstate battery.Yup, do that test, but 04+ test the system every so often even overnight so you may have a battery that is on its way out.
TYVM!Start with the basics. A test light and remove the battery cable. Insert the test light between the cable and the battery terminal you removed it from. If it lights it's drawing power the more power the brighter it will be. Then remove fuses one at a time until you find the circuit that is causing the drain.
