Turbocharged400sbc
i know its not a popular topic but looking for more info that i havent found.
i recall the torsen's needed an upgrade for washers, i recall dyno tech did the modifications back in the day.
well it seems the quaife i have does as well....the beginnings of spalling from the cross drive gears touching the case.
some at the ends with the oil/lube entry holes but the worst at the two axle gears where they touch the case
it is a really low mile unit but its starting...though some seems to be from burrs that were never removed.
im cleaning it up, having fun removing the chipped planets and worn pins on the OEM side... might grind/chrome/grind the bearing journal (rust got it fairly well in one area) im going to get the case and the cross gears nickle coated and toss it in... im looking at materials to machine out thrust washers now for the planets
just wondering what folks remember
