Toasty
I'm wanting to make an extension harness for the hud control switch, so i can put it on the left side of the dash.... i dont really want to cut the factory harness, so i need to be able to duplicate the pin setup that is in the hud switch itself. (i'm intending to use epoxy or something similar to make the body of the plug that will contain the wiring/pins to mate to the factory harness, and use a scavenged plug for the other end)
question is, is anybody here familiar at all with the packard/delphi plugs/pins to be able to point out what pin i could use for this? i know they're a flat blade style... i suppose i could solder on the wire and make do, but that doesnt seem right.
hmm... perhaps snipping the prongs off of a turn signal flasher that has the small pins, and using those?
