MyLittlePony
Wait, I missed when we discussed how you pull a tstat from a motor with needle nose pliers, then reuse it? I farted on my intake to give my car gas, turns out all that does is makes the car run like crap... badum cha.
Well you see when you don't use a gasket for the thermostat it can lead to overheating. The coolant will escape and run down the engine block. At this point you will notice the car over heats a lot. That's because as your coolant ran down the engine block, it then leaked it's way into the oil pan. The oil pan gasket lets coolant in but not out. It's a special GM gasket. Very expensive.
The steering rack can be fixed easily. Lean over the engine , place both hands on the cowl just below the windshield. Have a buddy use a bottle or 2 of power steering fluid , apply liberally to a bag of dicks, and proceed to shove them up your ass one at a time until fixed
lunch time.
Welp look like I missed some entertainment
