DJNight2k
ROLLER SOLD> Part out continuing in the parts for sale posting.
Well due to certain financial issues, I am now forced to sell my car before I finish the project. Not sure what exactly to ask for it, so I will entertain offers. Below is a list of what I have and have done.
I am sure I have more, I have been building and collecting parts for over 4 years to build this car.. I REALLY do not want to sell it, but I have no choice. Reasonable offers will be considered, within reason. she is my baby and parting with her is going to be very difficult. Thanks for looking and feel free to ask any questions you may have. Car is located in Lorain, OH. PM with any questions etc. IF someone wants to buy the WHOLE LOT of everything I Have, make me a SERIOUS offer and we will talk. I need to get this done ASAP so I would love to provide it all to one person to build this into the awesome ride I had planned it to be. RARE sunroof Pace Car. Number 1321/1500
Clicking on this pic will take you to a slideshow of the outside pics of the car.
- 1998 Medium Gulf Blue Daytona Pace Car GTP, 150k on the body, in very good condition, none of the usual rocker rot underneath common to most northeast cars. custom 3" catback to hooker mufflers and oval tips.Has Firebird wheels with spacers currently on rolling chassis. has smaller Monte Carlo Brake booster installed. Guy I bought it from had started some modifications to the car, started to relocate brake abs module, route AC on passenger side and had built custom fiberglass "beauty" panels to hide wiring etc on sides of engine. Welded brackets in for these panels. Some of the attachments for this remain welded to the body. I have included with the vehicle a complete "normal" ac system. Radiator support was modified to be removable, easily welded or bolted into place. Rear fender well lips are rolled for lowering/wider tires. This is a project vehicle and will need some finishing to get it on the road. Solid car. Car# 1321. ($1400)
- Engine - L67 stock bottom end, modified oil pan with oil return fitting built in for turbo, Cometic .065" thick head gaskets, ARP 12pt head studs, l67 heads checked, milled and light port job and gasket matched to L26LIM. L26 LIM/UIM custom powdercoated a metallic purple/blue that changes depending on the lighting etc like a pearl or HOC color. HV3, ST4 Cam installed with new cam bearings, NEW crow 130lb valvesprings, modded retainers and viton valve seals, ls7 lifters, custom length MANTON 3/8" pushrods, Low mile rockers with ARP rocker bolts, balance shaft removed and oil port tapped and plugged. New Melling oil pump and machined cover, NEW rollmaster double timing chain, all new GM gaskets etc. NEW GM water pump, ZZP Polished valvecovers powdercoated with clear so no constant re polishing needed. Cam, bearings and rockers/lifters all coated in cam lube during installation. 99+ alternator/tensioner bracket. throttle body adapter to fit L26 UIM. Dual Drilled flexplate. Probably other little things I am missing that are in/on the engine.. needless to say, paid a lot of attention to detail when I put this together. ($2000)
- GM STB included with chassis.
- Aluminum Subframe
- NEW Motor and trans mounts from WBS.
- Braided fuel line setup from metal lines to fuel logs with -6AN connections - feed is 90degree, return is straight fitting.
- Front bumper impact bar modified for better airflow to FMIC as well as hood latch support.
- New GM heater hoses and connector orings etc.
- NEW GM Battery tray
- GMPerformance sway bars F&R, GM Performance Trailing arms
- Interior in very good condition, leather seats (one tear in drivers seat bottom side), sunroof, HUD, A/C, etc car comes with extra dash housing due to one in vehicle being modified for a boost control by prior owner.
- I have a PCM tuned for this build, it is untested as of yet but done by a reputable member and using DHP software. The vin is for my silvermist car but same year etc and vin can be edited with DHP. If the engine sold complete I will include this PCM.
- Available but sold separately from the car - All items local pickup or plus shipping/handling.
- Transmission - FULLY built transmission assembled by myself (GM Certified transmission tech for 15 years) 300M input shaft, 7/8" chain, metal side cover gaskets, 90% of all internal components NEW gm parts, all parts with bushings in them were replaced with NEW parts (not just the bushings), NEW bands, clutches, 03+ sprags, 5 clutch input clutch from TEP, zpack 3rd with Sonnax Billet 3rd piston, all clutch packs set with optimal clearances for best performance per Dave at TEP's guidelines, TEP stage 2 valvebody/spacer plate, torlon lightweight checkballs, Transgo shift Kit, Hardened 4th shaft, ZZP 3000 stall converter - Trans has pretty much every upgrade aside from the ultra expensive and rare 1" GMR chain and Final Drive or drilled output shaft. Much time and care was taken building this transmission. Should be up to the task of handling the power the turbo will give it. Just remember to change the 7/8" chain every year or 2 depending on driving style/miles.(SOLD buickman104)
- Hot side, stainless front PLOG, custom z7 style (without W/G hookup) crossover, Custom modified rear manifold with turned primaries and original exhaust exit replaced with 38mm W/G mounting flange. Hotside pipes are ceramic coated black. , stainless 2.5" downpipe w/ 5 bolt turbo flange - DP is wrapped with DEI Titanium wrap and 2nd 02 bung welded in for Widebandand
- Turbo - Precision 6262 .63 a/r 5 bolt exhaust housing No shaft play, Compressor housing polished and powdercoated metallic purple/blue like Intake.
- TiAL 38mm w/g with 9psi spring installed (SOLD)
- Willing to sell the turbo setup separately if nobody is interested in chassis/powertrain package. From PLOGS to wrapped 2.5" DP, Looking for ($1500) SOLD GTPChristopher
- NEW blue aeroforce gauge, ($185) SOLD Swiggles
- Wolf Car Cover ($80)
- 60 lb/hr injectors ($185 shipped)
- ZZP Fuel Logs - early Round style with FuelLabs Fuel pressure regulator. Setup for AN connections, original fittings included as well ($200) SOLD Locally
- L26 Lower/upper intake manifold setup for turbo. Injector bosses plugged, brass barb for brake booster connection, lower pcv port blocked, coolant passages to upper intake plugged, egr tube plugged, runners slightly smoothed and gasket matched, HV3 included, powder coated metallic blue/purple ($275)
- NEW Glowshift boost gauge ($40)
- zzp triple pillar pod - latest style ($45)
- zzp hudpod ($20) SOLD Keatonregal
- EL blue/green gauge overlay with 04+ needles ($75)
- NEW HUMount custom grand prix turbocharged with red and blue led's ($100 shipped)
- Turbo Blanket ($40) SOLD SgtMarshal
- Stainless high flow catted TOG DP with 3" outlet ($150)
- NEW CXRacing Full size 3" in/out FMIC with 2.5" aluminum piping kit and clamps (do not have any silicone connectors, this is one of the missing links to finishing the project) but could be tig or aluminum welded together etc ($300)
- NEW Stattama BOV ($70 shipped)
- NEW Black ZZP square poly dogbone mounts ($40 shipped)pending
- Polished RAT style aluminum dogbones ($100)SOLD 98grand
- NEW GM black outer door "b" pillar trim ($60)
- Mini AFC 2.0 with extended wiring for remote mounting ($100) SOLD SgtMarshal
- Billet Breather SOLD SgtMarshal
- Caspers fuel pump rewire ($60)SOLD dsmuts
- NEW HighFlow Fuel 255lph fuel pump (outflows racetronix - From Tengis formerly of MOAR Performance) (venturi style installed in oem fuel bucket with NEW GM level sensor and strainers etc ($200) Will include extra clamps provided by Highflow Fuel for corrugated hose.
- NEW ZZP current generation plug wires - Black ($50)SOLD GTPChristopher
- Stage 1 voltage booster ($10)
- Powerbastards 205Amp alternator (99+ style) ($125)SOLD GTPChristopher
- DHP Powrtuner WITH laptop and software ($350)Pending
- Mille Miglia 1000 Silver 17" wheels with Hankook Ventus V12 EVO tires, like new ($650)Pending
- TSW Vortex wheels, NEW in box, never mounted 18x8 40mm offset ($750)
- NEW ZZP Oversized radiator ($125)
- NEW 99+ Coolant bottle ($40)
- NEW Stainless braided brake hoses (Blue) and stainless 5th brake line ($100)SOLD TravisGT2
- NEW C6 corvette front calipers modified to fit and powdercoated same purple/blue, corvette emblems machined off, was planning on putting reflective concepts caliper decals on them. Powerslot 12" slotted/cryotreated rotors ($350)
- GXP rear calipers powdercoated to match, all you need is the rotors. ($200)
- 2 Infinity Perfect 12 aluminum subs in custom trunk enclosure and Infinity 1600a AMP ($600)
- Custom Fiberglass/Carpet trunk Lid enclosure for 6.5" speakers with blue LED backlit lexan center display (currently with etched college panel in it) ($180)
- Clear corner lenses ($30)SOLD Wags81
- HID Ballasts (morimoto) and 9006 6000k bulbs ($70 shipped)
- Hydroboost unit and master cylinder with modified pedal pushrod to fit our vehicles. Have to drill and bolt in place of brake booster. ($150) No hoses are included with this system, custom hoses will be needed to complete the setup.
- ZZP Aluminum trans pan. Needs new drain plug threads. ($75)SOLD BrandonHall10
- TransGo Shift Kit, new unused ($40shipped)SOLD BrandonHall10
- Halo headlights, used but complete, never installed to try them out ($100)
- SFI Balancer 8 Rib Powerbond with 5% OD ($130 shipped) SOLD gambler87
