Hi everyone, I am new to this Forum but not new to working on cars or other forums. Also on the Impalassforum.com with the same handle and I'm quite familair with the Mechanical and electrical side of things.
Couple of Electrical Issues....Sorry, I know it's a lengthy read but I just want to include as many details as I can up front.
1) So I have a 2004 Grand Prix with the 3.8 L engine with about 140K on her and the Blower Motor for the Heater/AC stopped working. It was doing it off and on for a bit and the last time it stopped, I hit the Dash and it worked for a bit so was assuming it was the fan motor. I found the problem, just not the fix for it yet and looking to see if anyone else has seen this.
Here's some more details on what I did...After some initial testing I've done, I have found that the Fan works fine when 12V and Ground are applied directly to it. Started testing some of the leads going into the Resistor pack and if you look at the Schematic, Ground is on Terminal A of the 5 wire plug. I have continuity from this terminal to metal/chasis ground. The 12V signal comes from a 30A fuse (Main4 Fuse 30) in the underhood fuse box and feeds directly PinC of the 5 wire plug. The fuse is good, but I have no power going to PinC of the plug....actually there was about 4.5V I was picking up with the DVM. I pulled the fuse and the 1 side of the leg has 12V so it has power.
This is where I found the problem....if I check for continuity from the leg of the fuse holder to PinC of the connector that plugs into the Resistor Pack, I have no connection. I just temporarilly Jumpered a test wire from the fuse to to a backprobe on PinC and the Fan and all speeds work. So obviusly my problem is in the wire that the Schematic shows going from Fuse 30 to PinC that plugs into the Resistor Pack is open somewhere. Has anyone else seen or have an idea of how/where exactly this single wire runs? I don't want to cut into the factory harness unless I have to but if I do I will be sure to Solder and Heat Shrink the Connections. I'm going to remove the Glove Box this weekend and see if I can physically trace the wire back and hopefully find the break.
Phew
Now my 2nd issue....
For years we were dealing with a Humming and sometimes a whine that would come through the radio and would also vary with engine speed at times. A good ole RAP on the side of the dash would sometimes stop it OR make it less OR make it worse. Sometimes beeping the horn would cause it to return or hitting a bump in the road. Sometimes after turning the car off you could still hear a whine or crackling coming from the speakers that would go off after a few minutes.
I think I resolved this issue while working on the blower motor. While I had things apart, I decided to pull the dash panel and removed the Radio from the dash, cleaned the connections with electrical cleaner and reseated everything just to see if that helped. It actually seems to have stopped for now. Anyone else seen this issue or have other things I should check while I got the Dash apart?? BTW - Its the 6 disk changer with the Monsoon setup.
Many Thanks for listening and bareing with me on my long post.
Phew
