BillBoost37
at least you didn't overpay too badly.
I don't know if you can run a 97 PCM in a 99 even with the harness.if you mod the lim on any n/a 3800 it cant hydro lock ever again.
you could swap but its a bit more work, pcm wire harness from the donor car.
There's about a 13 wire difference to the pcm. But... I called Scott out on it and suggested using the 99 harness instead. It's very easy to mod a harness. Ask me how I know.
My 97 Bonneville had a 99 L36 harness that I modded for the firewall connector (would be relay center in a W body) to work. Ran a 99 pcm. At one point before I had a dhp I needed to have the correct vin, hence I made an adapter from 97 pcm to 99 wiring harness connector. It's a lot of wires to map, solder and hope you get right on the first try because you literally have one night to do it. FWIW I turned the key and it fired right up.
Well Bill it turns out it's a 98. I know I'll still have to mod the 99 harness and will pm you when that day comes but since it's only a year difference could I use the 98 pcm?
Do you have emission testing in your state?
I would drop the gtp engine into your car, make sure it runs and shifts good, sell the other tranny, and sell your orig engine. Part out the gtp that was t boned to the max, scrap. You may come our ahead.
if its a 98 pcm from the gtp, and your car is a 99 you could flash a 99 bin to it and make it work with some tuning changes like the tranny if you keep the na tranny.
what im saying is you have two good pcm's now 98 and 99 will swap bins with no issue.
a 97 pcm is its own animal and can only be used for a 97.
if you ever figure out what way you want to go, pm me, i can make all them changes in the pcm for ya. you just need to ship me one of the pcm's.
We don't have inspection here so I'm not too worried. I'm just trying to figure out how to make the performance shift button work and swap out the dic so I can have the crappy boost gauge until I hook up a real one. Bill let me know I'd have to modify the 99 harness for the map and bcs. First I have to get the motor/trans out to change gaskets. Plus I think the sc is leaking from the seal on the snout.
If they plug an OBD2 connector to read the car, then you want the vin to match. PCM would need to be updated.Yes bill I do have smog testing here.
And the BCS plug and now the wire for the perf shift. Anyone read what I write?all you have to change i think is the map pig tail.
the perf shift button you have to add a wire to the pcm and run a button off it. or take the knob from the 98 and wire it up. take the pcm wire from the pcm plug in the t boned car.
It'll run off the 98. Can't pass a plugged in test though based on incorrect vin. Trans tables will be wrong, as will the fueling and timing and cylinder airmass and a bunch of other things.you can try to run it off the 98 pcm then. its just your vin# that wont match and that dont really matter unless you have inspection.
dont run it on the 99 pcm, the timing is way to high. and the trans wont be happy at all.
