20+lbs of boost!?
kewGTP
Just thinking, if I remove 14.7 from those numbers than my boost levels would be correct. . . . Solved?
How much KPA are you seeing?
Like 145?
I just take the number above 100 because 0-100 kpa is not in "boost" yet. So like 145, just take the 45 and thats 6.5ish psi.
Like 145?
Yep anywhere from 145-165 KPA when WOT, doing your math makes sense and puts my boost amount in normal spec for its current mods. Thanks sir!
you're reading manifold Absolute pressure (relative to zero pressure absolute, like deep space) not gage pressure (relative to ambient barometer). so you have to subtract the baro reading (i.e. the "normal" air pressure)
