Hello. I have owned my 2001 GTP since 2006 and I bought it used with 35,000 miles. It now has 144,000 miles on it. I originally owned a 1997 GT that I bought new. I bought this one and sold that one back in 2006. It has had all of the typical Grand Prix issues that I am aware of. I have listed all of the repairs to date below. I did not include normal wear items like tires and brakes. The car runs great and idles perfect. I have used synthetic oil since I got it up until my last oil change. For the past year or so I have been noticing excessive oil usage. About 1.5 quarts or so every oil change. There are no visible leaks on the garage floor or around the valve covers or intake manifold that I can see. My oil pan has some seepage on it but not enough to drip onto the floor. Where is this oil going? I don't see any smoke on start up or while running. I switched to regular motor oil because I read that synthetic will make its way through any worn out seals, parts, etc. Switching oil types has not made any improvements as I am still loosing oil at the same rate. Any ideas?
In addition, I have been adding coolant monthly. About a 1 cup or so. There are no visible leaks that I can see. Where is this coolant going? I don't see white smoke from the exhaust. Repairs to date are listed below.
Leaking tail lights (replaced with used original ones from junk yard at 90,000 miles)
Leaking head lights (replace with aftermarket parts at 133,000)
Rusted front sway bar (replaced with Dorman part at 125,000)
Front wheel bearings (Replaced at 108,000)
Lower control arms (Replaced at 108,000)
Struts (all four replace at 108,000)
EGR valve (replaced at 133,000)
Valve cover (replaced by dealer under recall around 50,000 miles or so. I think it was the front one but I don't recall)
ABS module (had rebuilt at 85,000)
Driver's side window regulator and motor (replaced at 135,000)
Steering rack and pinion (replaced at 118,000)
Rear brake proportioning valve (replaced at 136,000)
Coolant elbows (replaced with Dorman aluminum ones at 135,000 miles)
Coolant level sensor (replaced at 100,000)
Thermostat replaced (110,000 miles)
PCV valve (replaced at 100,000 and 135,000)
New GM Spark plugs and wires (replaced at 100,000)
Mass air flow sensor (replaced around 115,000 miles with rebuilt one)
Heater motor resistor (replaced around 85,000)
Lower intake manifold gasket (replaced by dealer around 85,000 miles or so)
