I've been told by mulitple people the 04+ gtps will max out the maf and injectors before u go to a 3.4 pulley. My stock injectors went static on a 3.4 pulley trying to do a 140% duty cycle at 4,600 rpm in second gear at wot
you got lied to.
Is this the procedure I should go about doing to get my car tuned in
Yes. I'm with you guys here. Messing with ifr to change fueling is darkhorizon level stuff. No need to fudge numbers to get it to run well. Tune the maf. It's a long, tedious process but it's the right way.And I'm no pro, even less sobthan Scotty...but I'm not sure about #1. IFR, IMO, should be calculated based upon injector size. I don't think its one of those things you wanna go tweaking constantly. Every time you change IFR its gonna throw the rest of your tune off. I would get the data right based upon injector size you are using, and tune fueling with MAF table.
Which guide you talking about? Is it one in Bills db?
