zbban1
https://www.dropbox.com/s/zf00se5mp0j4cl1/2015-07-15 17.04.33.jpg?dl=0
1997 GTP, I'm only replacing because my old one has the outside lettering worn off of it and also my cruise hasn't worked since I bought the car a couple of years ago. I'm trying to get the cruise to work again, and have a cruise control module on the way. Fuses are good, brake lights and 3rd brake lights all work, so I'm thinking it's either the lever or the module.
I know where the 2 bigger main wire harnesses go, but the 2-wire connector with a black wire and a green w/white stripe wire is giving me fits! It wasn't hooked up when I took the old lever off and I've been doing numerous searches, watching videos, pics, but nothing helps. The closest I got was a venture/montana van and the guy installing the part plugged that little 2-wire connector into a round part under the dash, which I can't find in my car.
EDIT: Maybe that 2-wire connector is just there for OTHER vehicles, like that van I saw in the video? There's 2 switches that are mounted above the brake pedal, one is for the brakes and the other is for the cruise, if I'm understanding the setup correctly. The top (smaller one) is supposedly for the cruise, when you hit the brakes it disengages the cruise. It does have a 2-wire connector already attached to it so I'm confused...still.
PLEASE help!
PLEASE help!
