That "heavy knocking noise" you think you can get away with is gonna be a piston blowing apart. Ask a dozen forum members about it. You seem to think the pcm can pull timing fast enough to keep your pistons from chipping. 99 out of a 100 times maybe, but why risk it? Besides, your car WILL pull timing. It costs an extra 2 bucks per fillup to prevent that from happening. Why not?
Is there a video available to reset the TPMS? My monitor is not reading correctly.
I wonder where those rims come from? they sure do not look like the ones I had on my 2004 GTP. Are the rims 16" I will try and send a picture or two of my 2004 GTP and you can see the difference, or hopefully see the difference. My friend also had the 2004 Grand Prix and the rims you have are exactly like the ones he had on his Grand Prix, oh they are nice rims for sure.
Nope 17'sI wonder where those rims come from? they sure do not look like the ones I had on my 2004 GTP. Are the rims 16" I will try and send a picture or two of my 2004 GTP and you can see the difference, or hopefully see the difference. My friend also had the 2004 Grand Prix and the rims you have are exactly like the ones he had on his Grand Prix, oh they are nice rims for sure.
Help!Nice wheels from a 100ft away and immediately after you put air in them. They are 17 x 6.5 ,52 offset with 225/55/17 rubber.
One of the first major dollar jumps would be a wheel and tire purchase.
18 x 8, 35-40 offset with 245/45/18 rubber would make you very happy. You will learn to hate those wheels.
The only quick fix ( like I did with one that leaked 20psi a day) is to bring it to a good tire shop--not one of the chains.
They will grind the inner flange and goop it up with bead sealer. It held better than the other three did after that.
But come on....do you want to spend $30 or more per tire to try and nurse crap wheels along.
Think ahead and start looking for decent wheels and tires......you should be able to score a new set for around a 1000 if your shopping skills are good.
I don't know if you have typical winter there, but don't even think about those torque stars for winter beaters
