Please define my Aeroforce Parameters
silenthaven
I need to know the accurate values or expected readings for the following parameters. Answer as many as you can please and if you can explain their importance. Im wanting to figure out which 8 to cycle thanks.
Mods: 3.5 pulley 3" catted downpipe MSD wires NGK plugs 180 tstat K&N intake zzp Power log borla cat back
Trans Temp
MAF SENSOR LB/M
MAF FREQUENCY
THROTTLE POS. PCT-
FUEL %
IGNITION ADVANCE
PULSE WIDTH
SHORT TRIM B1
SHORT TRIM B2
LONG TRIM B1
LONG TRIM B2
O2 B1
O2 B2
IAC
ENGINE LOAD
TORQUE CONVERTERSLIP
TORQUE CONVERTER STATUS
Trans Temp 0-220º, anything over 200 is getting warm
MAF SENSOR LB/M
MAF FREQUENCY 0-11,000hz. Completely depends on throttle input and how much air is going past it.
THROTTLE POS. PCT- Ask your foot, thats how far it will be open.
FUEL %
IGNITION ADVANCE 0-45ish, again depends on engine demands and throttle input. Cruising around 20-40, wide open throttle 12-16.
PULSE WIDTH Again, throttle input based. Going slow it will be low, 0-8ish, WOT likely near 13-16ms.
SHORT TRIM B1 -20 to +20
SHORT TRIM B2 -20 to +20 un-used.
LONG TRIM B1 -16 to +16.4, if you ever saw +16.4 you have a vaccum leak.
LONG TRIM B2 -16 to +16.4, We do not have a bank 1 sensor 2, so that is not even used. We only have 2 o2 sensors and both are called bank one.
O2 B1 0-990mv, is will always bounce back and forth between random numbers, it's trying to achive the stoich rating of the fuel.
O2 B2 0-990mv, bounces around untill warms up and stays near the .400 to .600mv range if the converter is working correctly.
IAC
ENGINE LOAD ask your foot.
Over half of those I dont or wouldnt even watch as they are kinda pointless to view.
Trans temp, intake air temp, coolant temp, ignition advanced, knock retard, MAP in/hgs for vaccum and boost readings, MPG and volts were really the only ones I cared to watch.
Map reads vaccum, all engine create a vacuum while running.
Different motors make different amount but 95% run around -18 to -20in vacuum at idle, it can go higher on the negative scale to say -23 to -25 with drops in throttle.
Anything over 0 vacuum is postive, so boost/psi. Most stock L67 3800's make 6-7lbs of boost.
And our cars only use B1S1 and B1S2. As for bank 1 sensor 1 and sensor 2. We do not use anything that says bank 2 sensor 1/2.
Thanks. What are the correct MAP readings? Also I have a 3" zzp catted downpipe and am reading about 150 with no decimal is that right?
i mean the O2 B2 0-990mv you said reads .400-.600 mine says 150
If it's always near 150mv and not moving at all, then that sensor could be dead.
It should be switching back and forth as the car warms up, then most lock in the somewhere around the middle numbers.
Didnt you say there are no B2 for the grand prixs? So would I even expect an accurate reading from the O2 B2 0-990mv?
