How long have you ran it since doing the oil change?
I'd even throw some trans fluid in the oil to see if that will help quiet the motor down, it may take several hundred miles to start working.
And I wouldn't rule out an exhaust leak but I'd have to hear it to see if it's really a lifter noise or something else.
I would want to look it over extremely well and confirm it's the lifters making noise before pulling it apart to swap them.
sounds like a rod knock to me.
make another vid, this time hold the gas to say 2000-2500 rpm's, then just drop the throttle, let it drop back to idle on its own.
.5 quarts will work.
And that just sounds like a poor quality phone recording, it can't handle the noises the car makes and it's all choppy and scratchy.
Try recording the noise with something else.
no. start it up, then hold the throttle to 2500 rpm for 5 seconds, then let off the gas and let it drop back to idle on its own.
you can stand at the bumper to make the vid, dont bring the cam in close to the engine.
