2000 GP/GT rev limiter causes computer to cut off clyinders from firing
Bill Blair
2000 GP/GT 3.8 under hard throttle -rev limiter kicks in- preventing cylinders from firing thus engine runs rough -only happens under full throttle. Thought maybe need new flash to computer:th_sick1:
maybe your tranny is slipping like a muther? what your rpm's when the limiter kicks in?
or are you flooring it in park, and it cuts out? if so thats normal.
Under hard throttle at what RPM? are you actually hitting the rev limiter or what rpm does it do this? I don't get your issue. Need more info.
Thanks for all the reply's -I'm posting this for a friend who doesn't have internet service(shame on him!):th_shakinghead1: By the way he is a 20+ year mechanic -BUT not a tranny tech -this is his wife's car -he is driving trying to figure out what's going on, The rev-limiter kicks in @ 4500 rpm
below 4500 rpm the tranny shifts OK - so the car is drivable -as long as you don't get on it! Even with his mechanical background -he is stumped :th_scratchhead:
thanks again for all the input
The rev limiter is programmed into the pcm. Dont see how that would suddenly change. You have other issues, possibly ignition related but hard to say without knowing exactly what its doing. Could be as simple as plugs/wires.
if a 20+ year mechanic cant figure out it needs a tune up, oh boy o boy.
ask the guy if the check engine light flashes when he floors it. that means misfires, clogged cat, or its in need of a tune something fierce.
maybe its one of those things where the spouse is saying: "honey my car is broke." and the mechanic asks: "what is wrong with it?" and the reply is something ambiguous.
