idrivejunk
LOL Scotty yer pic looks like you have a hose connected to the foam. Perfect angle strikes again like that hitch ball jack handle thang.
Replace the solenoid as I am sure that is faulty if you got boost with it unhooked.yea I seen that I unhooked it now its running back to around 5.5 6 psi but the belts slipping bad u can hear it squeal at wot so pretty sure the belts slipping but I got it all back the way the diagram an the yellow motor looks I really appreciate it guys
if the fpr is on a hidden line, yeah it does look right now.
maybe the bbv is bad? does that lever at the bottom of it move when you rev the engine?
The Digital one shows full but the torque app an the mechanical gauge is only showing 5.0 to 5.5 psi I kinda figure the boost will go up hopefully quite a bit after the new belt gets here but idk I know the cam will drop it down sum was just curious about how much I should be looking for with the new belt an mods I really do appreciate all you guys help getting the whole vacuum situation worked out
I wouldn't even bother looking at the lego block light show, it's pretty much useless.
