silenthaven
I was wondering if just the front plog will be good enough to significantly lower KR and give me more power or if its useless without rear plog as well? No i cant do headers cause im in california.
it helps, but you really want a 3 inch down pipe. ca is a ***** about them too tho.
if you have a U bend in the down pipe, get that removed, it will help a lot. U bend delete killed off 3* of kr in my car. rockers took off 5* before the u bend delete that kille doff the last 3* i had. so yup, i had 8* kr bone stock lol
I have a zzp 3 inch downpipe catted. doesnt that downpipe delete the u bend? So just the front plog then?
just smogged it and then had it installed after. In 2017 i may try smogging it with it on since i have a borla exhaust maybe they wont question it? It seemed pretty relaxed as long as the zzp cat passes the sniffer. if not ill have to swap. I tried installing the dp myself but no dice. The manifold bolts were hard to reach and get a good torque on. But maybe that was cause they were stock bolts?it does. and thats the most its worth doing. then headers.
did you pass smog with that dp, or you swap it back to the stock one for inspection?
