Ok this just started, when I turn the wheel I get a whrul whurl noise and only when turning... it sounds like rough vinyl rubbing together.. it is not coming from the steering pump, the pump has been replaced and it is still there.
I'm also getting a similar noise although much quieter when stopping once you get to about 4 MPH then let it roll stop you can hear a similar noise outside coming from the front wheels like vinyl rubbing.. the noise stops when you get stopped, you can hear it as you speed up to about 5MPH then after that the noise is gone...
what in the world would make a noise like this in two different places? the wheel is concerning me the most... I've already had the rack/steering gear replaced once when the car was new for GRRRRR like noises when turning... the steering pump has been replaced twice now (i don't think it needed to be either time but they always say they are sure that is the problem, so far it hasn't fixed it)
