02NavyBlue
Re: What did you do to your Car today? Vol 2.0
Which would be a bad thing cuz you won't fix it lol
i used to like red and black. but everyone here has red and black lol
and god forbid it leaks oil, ill be able to see the trail.
that does sound good.
rails are black. every thing belt accessory wise is black on the front of the engine, blower will be more yellow and black.
headers are getting painted silver, lets see if this hi heat paint stands up to that. trans if i got the time will be painted silver too.
and im leaving my alt its natural finish.
Check the wire the runs along the control arm , you'll have to peel the loom back. I bet you probably damaged one of the wires from the impact.Got the last wheel bearing and cv axle on driver side all done today. Done all 4 wheel bearings, tie rod ends, driver cv axle and brakes on this 07 base gp.
Still getting code c0035 right front speed circuit. Do i need to replace the wire that goes into wheel hub and all way into engine harness? Car hit a embankment about 500 miles ago, its driving decent now, struts making a little noise but otherwise its good. Want these trac and abs lights to go away already.
This. the wires are inside of a harder black rubber tube thing, mine was cracked and full of water. Which is why 5ft of the harness was basically dry crap wire.Just having a place in the harness where moisture can make it's way to the connector will turn the light on just like a bad hub or harness. So when you inspect the wiring also check out the weatherproofing.
Why thank ya, I wasn't to sure if I was gonna like them. They don't look too ricer like, I'll keep them for now and maybe resell them down the road. Funny thing is my mom is really pushing me to sell my car to my sister, I wouldn't mind selling it to her I would just need to try to find a lower miles rust free Regal GS or GTP or maybe an SSEI for in the $3000 range.Russo, not too shab. Nor too terribly cheesy. At least yours looks somewhat racekar now.
Got my clips from Guz today, so I put the grills on. Only used 4 of them and then used a shat load of zip ties.
painted up the valve covers, bolted on the alt bracket, d/s dog bone mount.
removed the coolant ports on the alt bracket as mine go straight up, these were all over the place, hopping i got 2 o rings in my kits of gaskets.
built my hoist too.
then stashed it in the back lol
then my car started to act up shuddering and misfiring. so i had no tools with me so back to my friends where the engine is and swapped my icm. as i had two codes p1361 abd p1362 low voltage to ignition bypass, and loss of com to icm.
swapped the icm, its still acting up, it comes and goes. thinking it maybe the crank sensor or some thing dumb like that.
