Yes i didDid you get the crank gear chamfered?
Yes the same thought ran through my head the double roller look a little off but them i presumed it being it doesnt matter how much i try and lined it up perfectly, its gonna be a little off somewhat but as long aa the teeth or lined up with dot i should be fine.. Thanks guys!double roller week![]()
yes looks good - i just posted a similar picture the other day, James had some nice input as well
Now I remember a while back, another member maybe Reptile? sd because these are made for the aussie N/A cars, true "0" on the crank timing is actually negative a couple degrees on our cars....
I cant see how that is possible because both crank sprockets, stock and the DR line up exactly the same on the crank, keyway in same location as well
so it kinda had me worried for nothing and a bit confused?
I wish i grabbed a cam degree kit.. But funds didnt allow...The difference is between L67/L36. L67's have their cam timing retarded 2* from the factory so when you put the DR on (made for l36) it changes the timing.
Best way to be certain you have it set right and there are no problems with anything is to buy a cam degreeing kit and verify everything is timed right.
I did on my xp cammed double roller l36 and everything was within ~.5*
Thanks.. Motor is back in the car i wish you could tune.. But i went with zzpLooks good to me.
