Gtx has a turbo!! lol
Re: Gtx going turbo almost done:) 40th intercoolerd almost done lol
Don't give him that idea. Dip the whole w2a
Are you gonna put fangs on the front bumper or something? lol sorry man, we gotta give ya ****.
are you going to fix the crash bar with another tubular beam or something or are you just going to leave it janky, cut in half like that?
It's going to stay cut like that, help let in air I had talked to Sal and a few others they just got rid of it all together but I also saw a few just cut the center out like this, I could have cut the bar in the back and had the ic sit back behind it but I wanted to make sure I got enough air flow right to it
Maybe like one of the s2000 with all the teeth lmao jpjp
The FMIC looks (.)(.)'s
lol thank you
It's going to stay cut like that, help let in air I had talked to Sal and a few others they just got rid of it all together but I also saw a few just cut the center out like this, I could have cut the bar in the back and had the ic sit back behind it but I wanted to make sure I got enough air flow right to it.
make a brace that connects it somewhere or it's going to be 100% useless when you do crash your car.
It is going to be a summer car only, but if I crash my car I'm also losing the 2000 body kit lol, but I have some metal left I was going to maybe weld it on the top of the brace to go across but I'm not to worried about it
cleaned up the Northstar tb just waiting for the clear to dry while I'm at work
took a four hour drive to Indianapolis
so I just need my intercooler piping some fittings and gaskets and I should be good
so two ideas cutting out the Pontiac to help air for the intercooler,and then possibly tinting the red on the arrowhead black, what do you guys think?
she looked a little dirty so I moved her and gave her a bath lol
I did the clock work to the turbo to get it where it needs to be with oil lines and the way the cold side faces
cleaned off the sides of the 40th to put the moldings back on today,
I just need to figure out digital horsepower tuner, I'm having problems with getting it to even run, but with the tune for this and the last few things for things he gtx I almost have both of them running, the 40th runs I just don't trust it without a tune .
good job on both, almost there bro.
thank you, I need to weld on the new mufflers for the 40th with the gxp tips off the gtx, tune it and then some small stuff on the inside to get it the best for a dd lol. The gtx I just need to make the oil lines and intercooler piping, I'm swapping out to the stage 2 axles today and message the place for the ic piping to get the price, maybe I can make the oil lines from nappa or something we will see
my brakes are so rusty :(
got both axles swapped out today not to bad,I need about 140 for the ic piping and cupplers and then 30 for the lines almost there:)
put the 40th headlights in the gtx to see how it's going to look I can't wait till my set for it are finished
Ic piping shouldn't even be that much on ebay. I guess it depends on which stuff you go with. Anyway, I'm jealous. Lol
it's about 100 but I need other things as well like the cupplers, and a adapter for my dp, but thank you I want it done by the next week or two
