    TIPS:
97-03 DHP or HP tuner, off board tuner and top 1/2 L36 parts
Scottydoggs
Killa Bee
hey all.
ive got 5 off boards for sale, these are 97-03 set ups. and 3 power supply's i can add to one. or you'll have to buy a 12 volt power supply to power it up.
asking 42 shipped each, 5 more if you want a power supply, keep in mind the p/s will cost a bit more to ship with its size. if you want a p/s it will come soldered to the off board.
if you want just the off board black wires are ground, pink and red are hot.
location is Hackensack NJ 07601
one obd2 port had no mounting ears, so its a dangle plug on this one.
one p/s has a power switch, the other two do not. you just unplug it and the power is off.
i should have 2 04 up off boards soon, im waiting for pin diagrams to make it works.
these 5 units are double tested working too. all of them were tested for a second time 5 minutes before the pic was taken.
you can use a 12 volt inverter like this one for a power supply if you dont have one http://www.amazon.com/gp/product/B0...psc=1&smid=A29H9ZXM6Z907A&tag=viglink25855-20
NO OFF BOARDS LEFT all sold out.
also selling the top 1/2 of a N/A L36 engine. everything is plus shipping.
lim $25 SOLD
upper intake $25 SOLD
flex plate $25
tb with sensors, $25 SOLD
fuel rail with injector $30
balancer $30.
i have one icm $20 (coils not for sale) SOLD
egr and stand one tube is busted off. $15
valve covers SOLD
heads SOLD
and i have (2) L67 coil brackets $25 each. BOTH SOLD
also just found a erg pedestal and good tubes. $15. SOLD
Re: off board tuner rigs for sale :)
Good idea Scotty make yourself a couple bucks! Great guy here!! Glws!!
it seemed like a good idea, then i started the work part, i got a good 7 to 8 hours invested in them so far.
the plugs getting prepped up and cleaned of extra wires. i got to have 2 lb's of wire laying here. lol
Reptile and I have been meaning to try to build a few of these. I just need to find someone who has some old junky psu's laying around.
Nice Job!
Nice looking stuff... I might have to invest in one.. OR I could get off my lazy ass and make one myself. LOL
i got the 04 up off boards figured out. ill have them soldered up and pics posted tomorrow.
being guinea pig status first one goes for 25 plus shipping.
Re: 97-03 and 04 up DHP or HP tuner, off board tuner rigs for sale :)
got bored today, added a 12 inch power pig tail to each 97-03 off boards. all 5 tested one more time. all working perfectly.
also to cut down on any misunderstandings what this does. its to be used with a tuner interface, such as DHP or HP tuners
your dhp/Hp tuner goes into the obd2 port and the other plug goes into the pcm, the pcm plug will only fit in one slot, one way, you cant mess it up.
pcm reading.
and of course, you need a 12 volt source of power to power the off board up. this is not soldered up as its just for testing and showing you guys whats up with the set up.
thanks for looking :th_peaceout:
its not working. we're not sure why, hes tried moving things around and a few suggestions from others. still failing.
